![USB 3.0 NanoHub USB 3.0 NanoHub](https://www.electronics-lab.com/wp-content/uploads/2017/05/2017-03-22T06-45-42.457Z-nanohub-usb3-top.jpg.855x570_q85_pad_rcrop.jpg)
Muxtronics @ tindie.com designed a USB 3.0 mini hub. Source files here:
Are you familiar with my NanoHubs? Tiny, penny-sized USB hubs you can use to add additional USB ports in incredibly cramped spaces, like hacking projects or mobile devices? Whereas the original NanoHubs were all USB 2.0, limited to 480Mbps, this new NanoHub allows for transfer speeds of up to 5.0Gbps, as well as up to 3.0A of power delivery. The cut-off connector boards allow you to test your application before soldering it into your product, reducing the size of the hub from 27x34mm (about 1.1×1.3″) to 20x20mm (4/5ths of an inch on each side), with an overall thickness of just 1.55mm (1/16″).
USB 3.0 NanoHub – [Link]
Login
