![USB (5V) to Dual Output +/-15V or +/-12V Step-Up DC-DC Converter USB (5V) to Dual Output +/-15V or +/-12V Step-Up DC-DC Converter](https://www.electronics-lab.com/wp-content/uploads/2020/04/IMG_0853.jpg)
This USB to dual output step-up DC-DC converter has been designed to be used in industrial automation control equipment, sensors, isolated operational amplifiers and test & measurement equipment that require bipolar supply voltages. The module provides +/-15V or +/-12V DC load current up-to +/-100mA. An onboard PCB solder jumper is provided to set the output voltage 15V or 12V DC. The project typically provides 75 to 82% efficiency over most of the load range. It operates with current-mode feedback at 200Khz.
USB (5V) to Dual Output +/-15V or +/-12V Step-Up DC-DC Converter – [Link]
Login
