![USB to -5V Negative Voltage DC-DC switching Converter USB to -5V Negative Voltage DC-DC switching Converter](https://www.electronics-lab.com/wp-content/uploads/2019/05/001.jpg)
Now days USB power source is very common and available in many devices and power banks. This DC-DC converter provide -5V negative voltage from +5V USB power source. This converter can be used in a wide range of industrial automation control equipment, sensors, isolated operational amplifiers and test & measurement equipment that require bipolar supply voltages.
The Max735 is CMOS, inverting switch-mode regulator with internal power MOSFETs. It operates from 4V to 6.2V input supply, and provides 5V 200mA load current. The MAX735 employ a high-performance current mode pulse- width modulation scheme to provide tight output-voltage regulation and low sub harmonic noise. The fixed frequency oscillator is factory trimmed to 160Khz, allowing for easy noise filtering.
USB to -5V Negative Voltage DC-DC switching Converter – [Link]
