![Using a Current Shunt with a Panel Meter / Ammeter scale change Using a Current Shunt with a Panel Meter / Ammeter scale change](https://www.electronics-lab.com/wp-content/uploads/2016/05/using-a-current-shunt-with-a-pan.jpg)
This video gives you the basics of how to calculate and use a simple resistive current shunt with an analog panel meter to change the current that is needed for a full scale deflection. The notes page for this video can be found here.
Using a Current Shunt with a Panel Meter / Ammeter scale change – [Link]
Login
