![Vecow SPC-7000/7100 – Compact and Fanless Tiger Lake UP3 Embedded Box PC for AI-related Applications Vecow SPC-7000/7100 – Compact and Fanless Tiger Lake UP3 Embedded Box PC for AI-related Applications](https://www.electronics-lab.com/wp-content/uploads/2020/11/6518-e1605704789642.jpg)
Barely a month after Vecow introduced the SPC-6000 fanless embedded PC powered by an Atom x6425RE Elkhart Lake processor, the company is back to announce another ultra-compact fanless embedded box PC aimed at delivering powerful computing performance and outstanding graphics to meet the demands of the fast-growing AI-related applications.
Vecow SPC-7000/7100 box PC is powered by the latest 11th Gen Intel® Core™ i7/i5/i3 processor (Tiger Lake UP3) that supports up to 32GB DDR4 3200HMz memory and between 12W and 28W TDP. It also features the Intel® Iris® Xe Graphics that supports dual simultaneous and independent displays up to 8K resolution, alongside a 9V to 55V DC-in power input, optional full function SUMIT A, B expansion, one 2.5GbE LAN and TSN networking, which make it perfect for factory automation, service robot, cellular V2X, smart retail, Industry 4.0 and AIoT applications.
The SPC-7000 is exactly the same as the SPC-7100 but the company added fins to the metal top cover of the SPC-7100 for extra cooling; the reason for the difference in dimensions, weight and temperature range.
Features and Specifications of the Vecow SPC-7000/7100 include:
- 11th Gen Intel® Core i7/i5/i3 quad-core (Tiger Lake UP3) processor with 12W to 28W configurable TDP
- Intel UHD graphics or Intel Iris Xe Graphics for discrete-level graphics performance, supports DirectX 12, OpenGL 4.6, OpenCL 2.0, and max 8K resolution
- Up to 32GB 3200MHz DDR4 SO-DIMM memory
- 1x M.2 Key B 2260 Socket
- 1x SATA III (6Gbps)
- SPI flash for AMI BIOS
- 1x GbE via Intel Ethernet Controller I219LM with support for iAMT (Intel Active Management Technology), Wake on LAN, PXE
- 1x 2.5 GbE via Intel Ethernet Network Connection GPY215
- WiFi 5/6 or/and 4G/5G cellular with Nano SIM card slot
- Dual DisplayPort outputs up to 4096 x 2304 @ 60Hz
- 2x USB 3.1 Type-A ports (10Gbps)
- 2x USB 2.0 Type-A ports
- 2x USB 2.0 via internal header
- 2x COM RS-232/422/485
- 1x M.2 Key B 3042/3052 Socket
- 1x M.2 Key E 2230 Socket
- 2x Stackable Unified Module Interconnect Technology A/B slots with customized chassis (optional)
- Infineon SLB9670 TPM 2.0, SPI Interface
- 3.5mm Mic-in jack, 3.5mm Line-out jack
- Realtek ALC892 audio codec, 5.1 Channel HD Audio
- Optional DIN Rail and VESA mounts.
- Power, HDD, WWAN and WLAN LEDs
- ITE IT8786E Embedded Controller
- 16 mode ignition control
- 2-pin remote switch
- Watchdog timer, and,
- 9V to 55V wide range DC Power input, via 3-pin terminal block with V+, V-, and GND
- Operating System: Windows 10 or Linux
- Dimensions:
- Vecow SPC-7000 – 150.4 mm x 106.2mm x 48.1mm
- Vecow SPC-7100 – 150.4 mm x 106.2x 62.1mm
- Weight:
- Vecow SPC-7100 – 0.9 kg
- Vecow SPC-7100 – 1.3 kg
- Temperature Range:
- Vecow SPC-7000 – -40°C to 70°C (operating); -40°C to 85°C (storage)
- Vecow SPC-7100 – -40°C to 85°C (operating and storage)
- Humidity: 5% – 95%
- EMC: CE, FCC EN50155, EN50121-3-2
The company has not said anything on price or availability of the hardware yet, but you can visit the product page if you’d like to make further inquiry about the rugged computers.
