![Vicor DCM5614 Isolated Regulated DC Converter Vicor DCM5614 Isolated Regulated DC Converter](https://www.electronics-lab.com/wp-content/uploads/2020/04/2020-04-21-eenews-jh-vicor.jpg)
Vicor DCM5614 Isolated Regulated DC Converter comes in a VIA™ package, offers up to 96% efficiency, and operates from 180VDC to 400VDC. This DCM Converter features flexible mechanical mounting options with low top- and bottom-side thermal resistances due to the thermal management and power benefits of VIA packaging technology. When paired with downstream regulators and PoL current multipliers, the DCM enables power system architects to achieve power-system solutions with outstanding performance metrics. Vicor DCM5614 Isolated Regulated DC Converter is ideal for communication systems, defense, and aerospace applications.
- Isolated, regulated DC-DC converter
- Up to 1300W, 46.43A continuous
- 96% peak efficiency
- 451W/in3 power density
- Wide input range 180VDC to 400VDC
- Safety Extra Low Voltage (SELV) 28V nominal output
- 2121VDC isolation
- ZVS, ZCS high-frequency switching
- Enables low-profile, high-density filtering
- OV, OC, UV, short circuit and thermal protection
- Fully operational current limit
- Available in chassis-mount and through-hole VIA package
- 5.57in x 1.40in x 0.37in [141.43mm x 35.54mm x 9.40mm]
- PMBus® management or analog control interface
more information: www.vicorpower.com
Login
