![Vishay VCNT2025X01 Reflective Optical Sensor Vishay VCNT2025X01 Reflective Optical Sensor](https://www.electronics-lab.com/wp-content/uploads/2022/04/174051747.png)
Vishay VCNT2025X01 Reflective Optical Sensor is a reflective sensor in a miniature SMD package. It has a compact construction where the emitting light source and the detector are arranged in the same plane. The operating infrared wavelength is 940nm. The detector consists of a silicon phototransistor. The sensor analog output signal (photocurrent) is triggered by the detection of reflected infrared light from a close-by object.
- Package type SMD
- Detector type phototransistor
- Dimensions (L x W x H) 2.5mm x 2mm x 0.6mm
- Emitter wavelength 940nm
- Moisture sensitivity level (MSL) 3
- AEC-Q101 qualified
more information: https://www.vishay.com/optical-sensors/list/product-84895/
Login
