Waveshare ESP32-S3 GEEK Development Board, Based On ESP32-S3R2 Controller Chip, With 1.14inch 65K Color LCD, Supports WiFi & Bluetooth LE
1.294
The Waveshare introduces ESP32-S3 GEEK, a small and versatile device designed for developers and hobbyists. It looks like a USB Flash drive and has a tiny 1.14-inch LCD for interaction.
Inside, it has a powerful ESP32-S3R2 chip with a 32-bit LX7 dual-core processor at 240 MHz. It comes with 512KB SRAM (for temporary storage), 384KB ROM (for permanent storage), 2MB PSRAM (for additional memory), and 16MB Flash memory (for storing programs and data).
This product stands out because it comes with a 1.14-inch IPS LCD, showing images in 240×135 pixels with 65,000 colors. It also supports both 2.4GHz Wi-Fi and Bluetooth Low Energy, making it suitable for a variety of IoT (Internet of Things) applications.
The board has several interfaces, including a USB-A port, UART port, GPIO header, and I2C port, which make it easy to connect and communicate with other devices. Moreover, it has a MicroSD card slot for adding extra storage space.
The ESP32-S3-GEEK is a development board created by Waveshare, and designed for tech enthusiasts. It features a USB-A port, a 1.14-inch LCD screen, a TF card slot, and various other peripherals. This board supports 2.4GHz WiFi and Bluetooth Low Energy 5, and it comes with integrated 16MB Flash memory and 2MB PSRAM. It also provides an I2C port, UART port, and GPIO header, offering flexibility for your projects.
ESP32-GEEK-DIMENSIONS
Key Features:
  • Powered by the ESP32-S3R2 chip with a 32-bit LX7 dual-core processor running at 240 MHz.
  • Includes 512KB SRAM, 384KB ROM, 2MB on-chip PSRAM, and onboard 16MB Flash memory.
  • Features a built-in 1.14-inch IPS LCD display with a resolution of 240×135 pixels and 65,000 colors.
  • Supports 2.4GHz WiFi and Bluetooth Low Energy wireless communication.
  • WiFi supports different modes, including Infrastructure BSS in Station, SoftAP, and Station + SoftAP.
  • WiFi operates in 1T1R mode with a data rate of up to 150 Mbps.
  • Bluetooth supports a high-power mode (20dBm).
  • Internal co-existence mechanism enables Wi-Fi and Bluetooth to share the same antenna.
  • Includes onboard 3PIN UART port, 3PIN GPIO header, and 4PIN I2C port for easy interfacing.
  • Comes with a plastic case and cables for added convenience.
  • Provides online open-source demos and resources, making it easier for learning and development.
ESP32-S3 GEEK is available on the product page for an affordable price of  $12.99. You can get more information about the product on their wiki page
