Waveshare Pi5 Module BOX is a Mini Computer Kit for the Raspberry Pi 5
1.093
Waveshare Pi5 Module BOX is a multi-functional all-in-one mini-computer kit designed for Raspberry Pi 5. The most interesting feature of this kit is that it is made from aluminum alloy and includes the option to add a Gigabit Ethernet, PCIe to 4-ch USB3.2 Gen1 USB adapter board, or PCIe to M.2 interface card on the card. Also, the kit allows you to add Dual Micro HDMI to an HDMI adapter that gives access to two HDMI ports for connecting your monitor.
Previously we have written about many waveshaper products including the Waveshare PCIe-Based 5G HAT+, the Waveshare ESP32-S3-Matrix Dev Board, the Waveshare ESP32-S3-Tiny Board, and many more feel free to check those out if you are interested in the topic.
Waveshare Pi5 Module BOX Specifications
  • Compatibility – Designed for Raspberry Pi 5 (not included)
  • Case Material – Aluminum alloy
  • PCIe Adapter Options:
    • Module BOX-A – PCIe to Gigabit Ethernet
    • Module BOX-B – PCIe to 4x USB 3.2 Gen1
    • Module BOX-C – PCIe to M.2
  • Internal Space – Extra space for HATs and cable management
  • Adapters – Includes Pi5 HDMI and Type-C adapters for dual 4K outputs and dual power supply options
  • Cooling – Airflow vents with optional fan support
  • Dimensions – 163 x 91 x 43 mm
This Waveshare Pi5 Module BOX  comes in three variants the Pi5 Module BOX-A which features a PCIe to Gigabit Ethernet adapter board is aloe the BOX-B features a PCIe to 4-ch USB3.2 Gen1 adapter, and finally there is the BOX-C which includes the PCIe to M.2 interface card. The company also provides detailed instructions on how to install the Raspberry Pi 5 and the attachment boards in case which can be found on the company’s product page. You can also check out the company’s wiki page for more information.
The Waveshare Pi5 Module Box can be purchased from Aliexpress where it’s priced between $24.10 to $28.69 or you can check out the waveshare store where it is priced at $21.99 to $23.99.
About Debashis Das
view all posts by das
