![Weller WT 1014 Affordable Soldering Station Weller WT 1014 Affordable Soldering Station](https://www.electronics-lab.com/wp-content/uploads/2019/02/WT_1014_T0053442699.jpg)
1-Channel Soldering Station Set, digital 95 W with soldering iron WSP 80 Robust.
- Power unit WT 1, 1 channel with soldering iron WSP 80 Robust and safety rest WSR 201
- WSP 80 Robust soldering iron (80 W) with power response tips for all standard applications, robust version. Tip family LT
- OFF time, Process window, Lock function, Offset
Technical data
- Dimensions W x D x H (mm): 149 x 138 x 101
- Channels: 1
- Voltage: 230 V, 50/60 Hz
- Heating output: 95 W
- Display: Backlit LCD
- Temperature range: Adjustable from 50°C – 550°C (150°F – 950°C), Adjustable temperature range varies among tools
- Temperature stability °C: ±2
- Temperature accuracy °F: ±17
- Temperature stability °F: ±4
- Dimensions W x D x H (inch): 5.87 x 5.43 x 3.98
- Temperature range (depends on tool) °C: 50 – 550
- Temperature range (depends on tool) °F: 150 – 950
- Weight (ca) in kg: 1.9
- Equipotential balance
- Fuse: 0,5 A
- WT compatible
- ESD-safe
Introduction Video
This soldering station is reviewed on Elektor and Weller WT 1014 is available at ~€350 from various distributors online.
Login
