![Wifi Gate Controller is Arduino Compatible Wifi Gate Controller is Arduino Compatible](https://www.electronics-lab.com/wp-content/uploads/2020/10/WiFi-Gate-Controller-3D.png)
After years of using weak garage door openers and trying to position them just right so my solar powered gate 400′ away would open when needed I decided it was time to make a wireless controller of my own. 802.11 is a ubiquitous choice and with the right antenna range is not a problem. Two wireless modules consistently popped up when searching for low power embedded WiFi, ESP8266 and ATWINC1500. In the end I chose the ATWINC1500 module for it’s compatibility with Arduino and it’s low power modes. This board is fully compatible with the Arduino MRK1000 which includes a SAMD21G18 Arm processor and the ATWINC1500 module. I also chose to use MQTT. Recent projects showed how effective the MQTT client/server model is in this situation. I use Home Assistant for home automation and it directly supports MQTT.
This board is designed for and tested with a US Automation Gate Opener.
This PCB design uses my custom libraries available here Mike’s KiCad Libraries.
This PCB was designed with KiCad 5.1.2.
Note: The LMZ21700 Simple Switcher, SAMD21G18 ARM Processor, and ATWINC1500 WiFi Module have exposed pads on the bottom which requires either a reflow oven or hot air to solder properly.
For Bill of Materials generation, I use my version of KiBoM forked from SchrodingersGat.
The project sources are available on Github.com: https://github.com/mikelawrence/WiFi-Gate-Controller
