![Würth Elektronik WSEN-HIDS Humidity Sensor Würth Elektronik WSEN-HIDS Humidity Sensor](https://www.electronics-lab.com/wp-content/uploads/2021/03/o188644v209-Family_WSEN-HIDS_25250202100xx-e1615546241233.jpg)
Würth Elektronik WSEN-HIDS Humidity Sensor utilizes a calibrated and temperature-compensated digital output with low energy requirement to measure humidity and temperature with long-term stability. The WSEN-HIDS humidity sensor is based on advanced micro-electro-mechanical systems (MEMS) technology and is only 2mm x 2mm x 0.9mm in size. This sensor features an integrated analog-to-digital converter and temperature sensor, which can be connected to commonly used microcontrollers via an I2C or SPI interface. The software development kit offers a fast and easy way to individually set data rates and use the interrupt pin. The small size and minimized energy requirement of Würth Elektronik WSEN-HIDS Humidity Sensor make it suitable for data loggers, as well as stationary and portable Internet of Things (IoT) applications. For modern applications, Würth Elektronik offers developers an evaluation board.
- MEMS-based capacitive sensing principle
- 0% to 100% relative humidity range
- Embedded analog-to-digital converter
- Fully calibrated 16-bit humidity and temperature output
- I2C and SPI communication interface
- Selectable output data rate up to 12.5Hz
- -40°C to +120°C operating temperature range
more information: https://www.we-online.com/catalog/en/WSEN-HIDS
