![XENSIV™ TLI493D-W2BW 3D Magnetic Sensor XENSIV™ TLI493D-W2BW 3D Magnetic Sensor](https://www.electronics-lab.com/wp-content/uploads/2020/10/TLI493D-W2BW_SG-WFWLB-5-2-Combi.jpg_495080045.jpg)
Infineon Technologies’ 3D magnetic sensor is dedicated for space-critical applications such as BLDC commutation in micromotors or control elements
Infineon Technologies‘ XENSIV 3D magnetic sensor (TLI493D-W2BW) combines high-accuracy magnetic field measurements with an extremely compact footprint and exceptionally low power consumption (minimum 7 nA). This sensor offers up a host of exciting use cases including innovative human-machine interfaces in the form of industrial and consumer joysticks, ergonomic pushbuttons on domestic appliances, and highly precise position control in robotics.
- 3D (X, Y, Z) magnetic flux density sensing of ±160 mT
- Programmable flux resolution down to 65 µT (typical)
- Extremely small form factor: 1.13 mm x 0.93 mm x 0.59 mm (typical)
- X-Y angular measurement mode
- Power-down mode with 7 nA power consumption (typical)
- 12-bit data resolution for each measurement direction plus 10-bit temperature sensor
- Variable update frequencies and power modes (configurable during operation)
- Temperature range: -40°C to +125°C
- Supply voltage range: 2.8 V to 3.5 V
- Triggering by external microcontroller possible via I²C protocol
- Interrupt signal to indicate a valid measurement to the microcontroller
Applications
- Anti-tempering protection in smart meters
- Joysticks for medical equipment, cranes, CCTV-control, game consoles, and industrial applications
- Control elements in white goods (i.e. multifunction knobs)
- Ergonomic push-and-control buttons on domestic appliances and power tools
- Position control in robotics
more information: https://www.infineon.com/cms/en/product/sensor/magnetic-sensors/magnetic-position-sensors/3d-magnetics/tli493d-w2bw-a0/
Login
