![Zero Multi-Power Supply is Battery supported Zero Multi-Power Supply is Battery supported](https://www.electronics-lab.com/wp-content/uploads/2019/06/46b3d909954acaff83cf6c48abee7118_original.jpg)
This is a breadboard friendly power supply with multiple input options. It can be powered from a USB port or from attached AAA batteries. It also supports Lithium battery input, Single cell(3.7V) and Dual Cell (7.4V,Max:9V) all supported. Output is 2 way adjustable (2-Way Adjustable 1-5V output) or Way Wide range & Adjustable (Vin-14V) output*. The project is currently live on kickstarter and has 19 days to go.
Hi, Mike. Thanks for the post. But just correction. It only support single cell. Not support dual cells.
Thanks, noted that.
