Aaron-Tecksay Posted August 9 Report Posted August 9 The TS-M1035 is a high-speed BLE 5.1 Bluetooth module that supports serial port transparent transmission, master-slave mode, and AT commands. Users can easily modify parameters such as serial port baud rates and device names using the provided AT commands, offering flexible and straightforward operation. This module boasts excellent stability, ultra-low cost, and high reception sensitivity. It is available with either a built-in or an external antenna option, catering to various project needs. Model No.: TS-M1035 Features Bluetooth Version: BLE 5.1 Frequency Band: 2.402GHz-2.480GHz ISM band TX Power: -20dBm~+10Bm Receive Sensitivity: -95dBm Air Rate: 250Kbps/1Mbps/2Mbps Antenna: PCB Onboard / IPEX Antenna Advise Range: 80m Memory: 48KB RAM Size: 20*15*1.5mm Pin/GPIO: 16/12 Power Supply: 2.5~4.3V Operating Temperature: -40℃~+105℃ Peripheral Interface: UART/SPI/I2C/ADC Serial Transparent Transmission Rate: BLE 20KB/s Applications Smart home Location tracking Bluetooth electronic scale Intelligent educational equipment Vehicle testing equipment Measurement and monitoring system Bluetooth wireless data transmission Industrial sensors and controls Medical equipment monitoring and wireless control Quote
buymode Posted August 21 Report Posted August 21 Thank you so much for sharing the details of the TS-M1035 Bluetooth Module! The information you provided is incredibly helpful, and I appreciate the effort you put into breaking down the features and applications. This will be a great addition to many projects. Thanks again! 😊 Quote
Aaron-Tecksay Posted August 21 Author Report Posted August 21 3 hours ago, buymode said: Thank you so much for sharing the details of the TS-M1035 Bluetooth Module! The information you provided is incredibly helpful, and I appreciate the effort you put into breaking down the features and applications. This will be a great addition to many projects. Thanks again! 😊 if this module is suitable to your project, you can get some samples for testing first 😄 Quote
buymode Posted September 19 Report Posted September 19 On 8/21/2024 at 3:23 PM, Aaron-Tecksay said: if this module is suitable to your project, you can get some samples for testing first 😄 Thank you for the kind offer! I don't need any extra modules for my projects right now, but if I need something, I'll let you know ASAP. Thanks, buddy! 😊 Quote
